Can’t access my old email
Jayson1
Hi.
I no longer have access to my email address that was associated with my MyAccount. I also do not remember my password. How can I change this without having to login in since I do not know the password, and any reset emails are sent to an email address I can’t access? Thank you
1 REPLY 1
@Jayson1  use this direct link to support to help you regain access and you can then change your email and password if desired
send a  private message   To CS_Agents click
