2 hours ago
@I recently switched to the 50gb of 5 g Canada - USA plan which says it includes minutes - text messaging and video.
So to clarify I can call from USA to Canada? Text? And FaceTime?
I’ve never had such a plan and we travel to the USA a lot and usually add on a plan.
Is this correct? Especially the calling ?
an hour ago - last edited 35 seconds ago
@Burkey20 Just to add one thing since you mentioned especially calling, check that your phone is on Public Mobile's VoLTE approved list in the link below otherwise your only voice call option will be T-Mobile's 2G network which is spotty and gradually being shut down. The USA carriers have all shut down their 3G networks already hence the need for a VoLTE phone (or use a voip app because data should still work even without VoLTE).
https://www.publicmobile.ca/en/on/get-help/articles/volte
If your phone is not on the list it may still have VoLTE capabilities but no guarantee. If you are unsure you can test it before you leave Canada (turn off wifi and make a phone call, if the phone drops to 3G it doesn't have VoLTE).
an hour ago
Canada-US plan, you can call and text Canada numbers and US numbers from Canada or US without any roaming charges, you can use data in Canada and US up to 50 GB, once you use consume all data, data will stop till your next renewal
an hour ago - last edited an hour ago
@Burkey20 Yes it’s a true snow bird plan you can call to and from each country CAN/US from either country using talk text and data at home or in the U.S. . Just remember when in the US to have data roaming turned on in phone setting , and set network to 4G/LTE not 5G and make sure your connected to T mobile or AT&T some have also confirmed Verizon works in some places so be sure to test which partners work best for you and your location in the U.S.
