Can somebody please explain…
FOFF
What the heck the difference is between the 50G plan for $65 ($55 if you buy for 90 days) and the 50G plan for $80 ($65 if you buy for 90 days)?? I must not have had enough coffee today because reading through and trying to make sense of these identical plans for different prices is making my head hurt…..
8 REPLIES 8
HI @FOFF   you will get 50G all along once you joined
FOFF
Thank you!
FOFF
Okay thank you. I’m sure there’s gotta be a clearer way to word their plans!
@FOFF   No, you won't loss it.  Once you are in, the price and data are fixed
it said 25GB + 25GB because the original $65 plan was supposed to be 25GB (at least they try to word it that way)
So, no worry it is a limited time offer but not limited time pricing or bonus
FOFF
And the meaning of the asterisk beside thr 26g+25g of the cheaper plan, while the $80 plan says a straight 50g?
FOFF
But there’s an asterisk beside the 25g+25g of the cheaper plan with no explanation of the * in the fine print. Does that mean you’ll lose 25g of your data at some point?
HI @FOFF
No difference.  Only difference is $65 is a better deal.  The contents for both are exactly the same
@FOFF  the $65 is a promotion deal only, it can go away any time
(but if you joined before promotion ends, the price and data stays with you until you change plan yourself)
