11-23-2023 09:13 AM - edited 11-23-2023 09:15 AM
As title.
I transferred my number yesterday morning. Since then I was able to send text messages and use the 5G network. However, I can’t receive any text messages and calls.
I didn’t receive any text messages about the transfer request from Fido.
Whom should I talk to?
Joining Public
11-23-2023 05:14 PM
@FaFanFann Check your community mailbox, envelope icon top right or select Messages from the drop down menu at your avatar if no envelope icon
11-23-2023 04:25 PM
Can I have this number? I used esim before I transferred so I don’t have the chance to reply my old service provider. Not sure what should I do now. Thanks!
11-23-2023 10:35 AM
Thank you @Phil_Adelphus ! My transfer is completed now
11-23-2023 10:10 AM
@Andres0405 Check your community private message inbox, either envelope icon top right or click on your avatar and select Messages
11-23-2023 10:00 AM
I Definitely did this, do you mind sending it to me as well
11-23-2023 09:16 AM
@maggiemak Did you leave your old carrier sim in the phone and reply YES to their port authorization text? I will private message you a number to call (it's not to be posted on this public forum. Check your private message inbox in a few minutes.
