05-21-2019 03:00 PM - edited 01-05-2022 05:01 AM
Can not receive text messages from anyone even myself. I have powered off phone, removed battery and have cleared memory and storage. Anyhelp would be great.
05-21-2019 07:06 PM
@Spider wrote:How do I conyact the moderator
Here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and give them details of your problem. Waiting time is few hours to 2 days. Be patient.
05-21-2019 07:03 PM
05-21-2019 03:55 PM
@Spider There are some problems in texting in the past few weeks. The annoucement said it was resolved. However, you should contact the Moderator and get it solved soon.
05-21-2019 03:22 PM
@Spider, looks like you should contact The Moderator Team. Wait time is few hours up to 2 days. Meanwhile, you might also want to provide more info here if you want some help from fellow customers.
05-21-2019 03:19 PM
It just stop working in the last day or two. Was working both for sending and recieveing
05-21-2019 03:16 PM
05-21-2019 03:14 PM
Been with public for several months and I can send messages to others bit can not receive from others or myself.
05-21-2019 03:08 PM - edited 05-21-2019 03:09 PM
@Spider wrote:Can not receive text messages from anyone even myself. I have powered off phone, removed battery and have cleared memory and storage. Anyhelp would be great.
@SpiderSMS or MMS or both?
Can you send messages?
When did you sign up to public mobile? Did text messages ever work?
What happens if you text yourself? Do you get it?
