06-23-2019 09:24 PM - edited 01-05-2022 05:31 AM
Just activated Public SIM card yesterday, it says prepaid SIM card, but my plan is $25 plan. Sometimes when I make a call, announcement says long distance call may apply. Is this prepaid SIM card right for the $25 plan?
Sometimes I coundn't make or receive call, couldn't send or receive text. I find out each time I received this call -- 2-247-811-0378, I have to restart the phone then it works, I can make call or send text again. I don't want to restart the phone so often. Can you help?
Moved from lounge by mimmo
07-06-2019 09:59 PM
Solved. thanks.
07-05-2019 06:31 PM
Hi jerry11,
I'm really sorry to hear that you are experiencing this issue, but we can surely help you find a solution
In order to do so, can you send us a private message via the Community? Please click on this link: https://goo.gl/JnHqMR
Kind Regards,
Public Mobile Moderator Team
07-04-2019 10:49 PM
Thanks.
07-04-2019 10:48 PM
Thanks. I'll try it.
06-23-2019 10:15 PM
@superdebator it is most likely a phone issue not an account issue. More info is needed from the posted before suggesting to contact moderators.
06-23-2019 10:13 PM
Hello,
Please contact the moderator in PM, they'll be able to help you out.
Cheers
06-23-2019 10:10 PM
Try dialing 1 in front of the number to get rid of the long distance charges may apply
As for restarting what phone are you using make and specific model #.
