Can not activate my phone
shuyang
When I try to activate my phone, I can not go through 2/6 step. Why?
@shuyang
If this is first activation with PM?
If you have an existing account, you can’t add another line to the same email address so 1 account/1 email.
HI @shuyang
the question is .. that email address, is it currently tied to another My Account on PM already? or it was used on another account before , even it is not inactive?
PM is email must be only used on one My Account. If you have used that email address on another account, then you need another email
if you never used that email on My Account, that could be a glitch, you can either submit ticket with agent and get them look into it or you can just use another email address
if you want to submit ticket, please message them:
shuyang
Why do I use a different email? My account email is not okay?
HI @shuyang
Step 2 of 6 is account creation.  If you have used that email before with PM account, try a different email
(Actually I would try using a different email address to create a new account anyway just via step 2)
