11-20-2018 03:54 PM - edited 01-05-2022 02:33 AM
11-20-2018 06:29 PM
11-20-2018 04:30 PM
Login to your account and see if data shows under Data & Add-ons. If not, you've used it all up. If there, follow the suggestions already given for APN after being sure cellular data and roaming are ON.
11-20-2018 04:01 PM
@Ligongou wrote:I bought a new phone recently and lost access to my data. I have the same SIM card as I had previously. The new phone is an Asus phone. My daughter has the same issue.
Thanks,
Have you checked the apn settings on it?
Here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
