Can load fund purchased at shoppers
Forouzsiassi
I got stock in resume activation page
slusagm
That is a login problem
But you can still load the voucher first. call 1855-4PUBLIC from another phone, enter your number and follow the prompt to load the voucher
Chalupa_Batman
Hello @Forouzsiassi
If you're stuck in "resume activation" page, there are two things that can cause that. One, you are trying to sign up the service with a Voucher which can not work for you but have to contact a CS Agent to set up an account for you to use one. Two, your account isn't fully set correctly and a CS Agent needs to connect them.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact them.
hairbag1
@Forouzsiassi
use your cell and dial 611 to add them to your account.
added...I'm assuming you mean you want to add those vouchers to your account for regular plan renewal. If you meant something different, please explain what you're wanting to use the vouchers for.
