09-14-2023 04:16 PM
I'm on ODSP and money is tight.My phone is on its last lags can I still buy a 4g phone instead of a 5g phone as the cost is way cheaper for 4g.Im in Kirkland Lake Ontario.Will 4g still work on a 5g network when we go 5g.
Thank -You
09-14-2023 04:58 PM
HI @Popeye1961
of course you can use 4G. Those 5G phones are more costly just becaue they are newer, not really because of 5G
and you can stay on a 4G phone for very long, so just buy
But what phone you are buying?
09-14-2023 04:56 PM
Are you looking at a particular phone? There are cheap phones at Staples and other electronics departments that would likely work here.
09-14-2023 04:17 PM - edited 09-14-2023 04:18 PM
@Popeye1961 wrote:I'm on ODSP and money is tight.My phone is on its last lags can I still buy a 4g phone instead of a 5g phone as the cost is way cheaper for 4g.Im in Kirkland Lake Ontario.Will 4g still work on a 5g network when we go 5g.
All Public Mobile plans give access to the same networks, so yes - assuming that your phone can connect to a 5G network in that location. When Public Mobile advertises plans as being 3G , 4G, or 5G, that's only about the maximum possible speeds.
09-14-2023 04:16 PM
@Popeye1961 Yes absolutely 💯
