Can I have 2 phones on 1 plan? or do I have to make 2 separate accounts?
Bill350
hi @Bill350
a reminder, when you create the new account, make sure you grab a friend referral code from the first account and use it for the activation to earn the friend referral rewards for both accounts ($10 one time credit on the new one and 1 Public Point per cycle on the old one )
Bill350
Ok ty
eddieO
@Bill350 with Public Mobile, each phone must be on it's own account, which is setup with it's own email address. If you try using the same address for more than one account you will mess things up and will need to get a support agent to fix it, so best to avoid
