07-17-2023 08:58 PM
Hi, there. I have an unlocked iPhone 14 pro max. I’d like to use esim instead to use a nano SIM card. May I?
07-17-2023 09:10 PM
@LaoFun- I wish I knew the source of all the theorizing about if and when you might be able to change. As I understand it so far, there's been no mention of future plans.
07-17-2023 09:06 PM
@LaoFun you would eventually able to use eSIM, but not at the moment
Due to some system limitation, migrating physical sim card is not feasible at the moment
But hold on and keep an eye on the Community, likely you will be able to do it soon, hopefully in a month or two.
07-17-2023 09:02 PM - edited 07-17-2023 09:03 PM
@LaoFun no eSIM is only for new activation for now . Not existing customers . So only way to work around it would be to port you number out of PM and create a new PM account and port number back in on eSIM activation . But honestly not worth the time and effort and rewards you lose if you happen to be in old rewards system
07-17-2023 08:59 PM
You can sign up a new account and use an esim. But you said "change" and "instead". No you can't change. You need a new account.
