07-01-2021 03:59 PM - edited 01-06-2022 02:40 AM
Hi there,
My plan has 250MB of data and that has always been enough for me, but now I forgot to turn off driving directions while I was driving around and it consumed almost all of my data in one afternoon.
Is there a way to add to your data as a one time thing?
Thanks.
07-01-2021 05:01 PM
At pm add ons are what an add on should be....you need a little extra you add on a little extra rather the provider assuming you need to add on extra every single month. If that was the case you wouod increase your data plan rather than pay the higher price for add on data. Fortunately add ons at pm also have no expiry so they continue to roll over each month until completely consumed.
You may want to consider purchasing the $15/1gb as it offers better value than the $5/200mb (×5=$25/1gb). Keep in mind the 75% and 95% usage texts include all data on the account not just plan data.
07-01-2021 04:04 PM
Glad to hear, I thought add-ons were recurrent as becoming "part" of your plan.
Thanks.
07-01-2021 04:03 PM
Got it, thanks!
07-01-2021 04:01 PM - edited 07-01-2021 04:02 PM
@dearmasmichael yes, you can buy the 200MB or 1GB data add on.. Make sure adding Add-on is a 2 steps press: 1 Load Fund then 2. actual buying. Many people miss the Step 2.
Also, all add-on has no expiry. So, if it is not used up, it will roll over to the next month and will be dipped into it after the regular data limits are used up
07-01-2021 04:00 PM - edited 07-01-2021 05:13 PM
@dearmasmichael wrote:My plan has 250MB of data and that has always been enough for me, but now I forgot to turn off driving directions while I was driving around and it consumed almost all of my data in one afternoon.
Is there a way to add to your data as a one time thing?.
All add-ons are one-time purchases.
