Issues With eSIM
SilverKat
Hi,
I just signed up for Public Mobile yesterday with an eSIM but am having issues.
It works for a while but sometimes when I go to text, I get the message "Please insert a SIM card to continue.
When I restart my phone, I can send texts again but after a bit of time, the same thing happens...
I might order a physical SIM card but I'm hoping to resolve this issue.
Thanks!
Kat
SilverKat
Thanks so much for your detailed and quick response! I just purchased a new eSIM, but it had trouble installing it. I restarted the phone and now I don't know where to find the new eSIM number or a way to install the new one.
Thanks,
Kat
slusagm
if you want to change to physical sim, but it in person from Telus or Koodo store (make sure to ask for Public Mobile sim card)
then login My Account, go to Profile page, and click the pencil beside the sim card number to update
HI @SilverKat
try to get a free replacement esim and it should fix the problem.  Download the PM app on the new phone, login to the app, go to Account page and choose Buy sim card and select eSIM.
the system might still charge you the $5.  Pay and install the esim first.
After the new esim is installed, submit a ticket with PM agent and for reimbursement.  You can submit ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
