Calls go to voicemail
Lache
Hi 👋
why are the calls going directly to voicemail?? My phone doesn’t ring 🤔
Phil_Adelphus
@Lache   If this is an iPhone make sure you haven't accidentally moved the silent switch on the side, happens quite often.
BRILLIANT! I always forget about that @OlivierR
If you have the iPhone, recent updates have turned on the block unknown numbers option. Go into your settings and turn it off then reboot. See if that works.
OlivierR
Might be your phone, have you enable any doesnt distub setting on your phone or airplane mode?
Chalupa_Batman
Hey @Lache
When was the last time you restarted your phone?
Also, you may wish to reset your network settings and reboot. Just know that will erase all wifi passwords and blue tooth items. You may need to submit a ticket to ask Public Mobile to reset your network on their end.
To submit a ticket, start with the chatbot at the bottom right corner.
Or the following link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
