2 weeks ago
Hello, I just activated this service yesterday, data works fine, I can call someone, but when some else calls me, my phone rings, but only rings once, and about 6 seconds, call will go to the voice mail, this caused me missed a lot of calls, I feel this has to do with some kind of call waiting/forwarding issues, so I cleared all kinds of call forwarding rules but still no help. My another line with Rogers on the same phone works fine, I am using iPhone 14 Pro Max.
2 weeks ago
thanks @Phil_Adelphus
@Michael_Li123 , please confirm if your Carrier Profile for Public Mobile is updated
also as a test, can you please disable (but not delete) your other Rogers esim? Just go to Rogers esim and toggle off "Turn on this line". And go back to Public Mobile esim and make sure it is togged on with "turn on this line" and set it as "Primary"
Also try to Reset network settings
2 weeks ago
@softech iPhone 14 Pro Max
2 weeks ago
what phone do you have?
2 weeks ago
Thank you for the reply! I am on dual ESIM right now, the other one is Rogers, works normal, and wifi calling is off.
2 weeks ago
@Michael_Li123 Have you used dual sims on that phone before? I wonder if that could be related, for example from Apple "If you don’t turn on Wi-Fi Calling for a line, any incoming phone calls on that line (including calls from emergency services) go directly to voicemail (if available from your carrier) when the other line is in use; you won’t receive missed call notifications." I may be getting ahead of the possible causes here though, it may be something more simple than that (PM doesn't have wifi calling).
2 weeks ago
Hello thank you for the reply! Yes porting is completed, my old SIM card is SOS.
2 weeks ago
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins, did you get the text from your old provider?? you sure the port was completed?? Can you put your old provider sim card back and check if it still works. If it works, the port was not done and in fact the port is stuck
