06-09-2024 09:26 AM - last edited on 06-09-2024 12:57 PM by computergeek541
My account shows many outgoing calls to 1(647)580-4001 from a few seconds to almost a minute. It was not possible for me to make these calls. Any explanations? How to stop this?
06-09-2024 10:19 AM
This is your voice mail. Every time call ends in vmail you will see that number. It will not use your minutes if you have a limit.
06-09-2024 09:46 AM - edited 06-09-2024 09:48 AM
List of Public Mobile voicemail numbers.
Access Number | Province | CNAC Rate Centre | Intended Serving Area? |
403-371-6245 | Alberta | Calgary | Southern AB 403/587/825 (Old Mike #) |
587-580-4001 | Alberta | Calgary | Southern AB 403/587/825 |
587-580-4002 | Alberta | Calgary | Southern AB 403/587/826 |
587-580-4003 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4004 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4005 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4006 | Alberta | Calgary | Southern AB 403/587/827 |
587-580-4007 | Alberta | Calgary | Southern AB 403/587/827 |
587-588-4001 | Alberta | Edmonton | Northern AB 587/780/825 |
587-588-4002 | Alberta | Edmonton | Northern AB 587/780/825 |
778-580-4001 | BC | Whalley | outside greater Vancouver area |
778-580-4002 | BC | Whalley | greater Vancouver area |
778-580-4003 | BC | Whalley | Outside greater Vancouver area |
778-581-4001 | BC | Whalley | BC 250 |
778-581-4002 | BC | Whalley | BC 250 |
204-588-4001 | Manitoba | Winnipeg | Winnipeg 204/431 |
204-588-4002 | Manitoba | Winnipeg | Outside of Winnipeg 204/431 |
506-588-4001 | New Brunswick | Moncton | NB 428/506 |
902-580-4001 | Nova Scotia | Halifax | NS/PEI 782/902, NL709/879 |
867-688-4001 | NWT | Yellowknife | NWT/NU/YT |
705-780-4001 | Ontario | Barrie | ON 249/705 |
289-680-4001 | Ontario | Hamilton | ON 289/365/905 |
226-580-4001 | Ontario | London | ON 226/519/548 |
613-581-4001 | Ontario | Ottawa-Hull | ON 343/613 |
647-580-4001 | Ontario | Toronto | ON 416/437/647 |
647-580-4002 | Ontario | Toronto | ON 416/437/647 |
647-580-4003 | Ontario | Toronto | ON 416/437/647 |
647-580-4004 | Ontario | Toronto | ON 416/437/647 |
647-580-4005 | Ontario | Toronto | ON 416/437/647 |
647-580-4006 | Ontario | Toronto | ON 416/437/647 |
647-580-4007 | Ontario | Toronto | ON 416/437/647 |
450-320-4001 | Quebec | Granby | Outside Montreal 450/579 |
438-580-4001 | Quebec | Montreal | Montreal 438/514 |
581-580-4001 | Quebec | Quebec City | 367/418/581 |
819-588-4001 | Quebec | Sherbrooke | QC 819/873 |
306-580-4001 | Saskatchewan | Regina | Southern SK 306/639, Edmonton |
306-580-4002 | Saskatchewan | Regina | Northern SK 306/639 |
All credit goes to user Nezgar
06-09-2024 09:44 AM
@Cracker-jack no worries, that is just Voicemail number
the usage history will record calls that routedto voicemail or when you check voicemail yourself
