Calls dropping, "No Network Available" despite full bars
BrandonMB
Hello all! My spouse and I are having some weird issues.
Since at least noon today, calls have been coming through intermittently. When they do come through, after about 15 seconds audio cuts out on one side, then the call drops with the message "No Network Available" popping up at the top of the screen. This happens at random to both of us despite having full bars, with (seemingly) no issues with texting or data. This also intermittently happens when calling our voicemail, or other family members on different phone networks.
Multiple restarts, sim card removals, and toggling of airplane mode have not changed anything over the course of 6 hours. We both have Samsung S9 phones, 3G plans, and have been with PM for a few years.
Anyone else having this/similar issues? We're in west end Toronto, could it be a tower issue? Any insights would be handy!
7 REPLIES 7
gpixel
@BrandonMB
3g is being decommissioned at an accelerated rate. I would start looking for a new device that supports volte at PM.
https://www.publicmobile.ca/en/bc/get-help/articles/volte
scroll to the bottom of the page to see compatible devices. there are also devices that are not on the list and they are compatible, but I would stick to a device no older than 2021 and the Canadian version.
Priority
Whenever I face this issue, it's either the calling or callers account that is suspended.
Your Account status is currently Active?
Hi @BrandonMB
haha, your Community name fools me the 🤣
Try this, change your Network mode to 3G and try to make calls and let us know if it works
Also, check in different area
If same, try Reset All networks first and if that does not help as well, please submit a ticket with CS Agent here and ask them to refresh your account on the system:
BrandonMB
Hi @hTideGnow
Currently in Toronto, Ontario
HI @BrandonMB
you are living in Brandon,  Manitoba?
if you are, then there is a problem with the 3G networks and that's why the problem
https://productioncommunity.publicmobile.ca/t5/Get-Support/Text-From-PM-About-Changes-To-Manitoba-Pr...
To resolve the issue, you need a VoLTE phone that is whitelisted on PM's network.  Sorry, S9 is not one of them, you need a much newer generation of Samsung phone :
https://www.publicmobile.ca/en/on/get-help/articles/volte
BrandonMB
Hi there! Thanks for that info.
For clarity, we both have the Samsung Galaxy S9.
HI @BrandonMB
what phone you are using?
PM mostly use 3G for voice.  While you see full bar, it could means only 4G for full bars, when you got a call, it will try to go back to 3G and your 3G might not have full bar
Please let us know what phone you have
