Calls cutting out
04-20-2020 02:43 PM - edited 01-05-2022 10:27 AM
I keep having issues with local or within Canada calls. The call will start out fine and if it lasts more than a few minutes I will suddenly start losing the other side (long blank pauses in the middle of the person talking) or they complain that they are losing me. I often have to hang up and call again. Any ideas what this could be? Anyone else having these issues?
04-24-2020 02:22 PM
@Roxyroller It might be interesting to look up where your local Telus towers are in relation to your location: http://www.ertyu.org/steven_nikkel/cancellsites.html
You could see if trying a call when closer to one of them helps at all.
Also, if you can note if the calls were to people who were also on a cell phone, or a mobile phone. If it happens when calling a landline, you can be fairly certain the issue is with your mobile link. Otherwise, you can't really be sure if it's you or them, unless you call them from a landline.
04-23-2020 03:10 PM
@Roxyroller wrote:I keep having issues with local or within Canada calls. The call will start out fine and if it lasts more than a few minutes I will suddenly start losing the other side (long blank pauses in the middle of the person talking) or they complain that they are losing me. I often have to hang up and call again. Any ideas what this could be? Anyone else having these issues?
I have had the same issue while making calls to the US. I get those long blank pauses mid conversation as well. Once called the old fashioned way, the other was with Viber. Same result. Within Canada...not so far. Weird... Anyone else experience this?
04-20-2020 04:15 PM
@Roxyroller Does your phone have a diagnostics mode that you can dial in and run a test on your microphone etc?
04-20-2020 03:16 PM
@Roxyroller , what you are experiencing might be local load factors in the network. Given the ongoing social distancing situation, the loading on the network is far from normal and we are seeing weak links in the chain being exposed.
04-20-2020 03:09 PM
This happens to me a lot when taking to one particular person, he is most of the time in the car and often using Bluetooth earpiece, he is with telus. I'm assuming it's just because he's moving and switching connection from tower to tower. I doubt Bluetooth has really anything to do with it, but if it does it doesn't help
04-20-2020 03:01 PM
From what I have read there is a huge strain on the system right now and all mobile companies are trying to scale up their operations.
04-20-2020 02:55 PM
@Roxyroller Never faced this. If previous advice didn't help, click on ? on bottom right and follow directions to create a ticket with moderators, and they can restart your account on their end. It may solve the problem.
04-20-2020 02:48 PM
No @Roxyroller , Could you please switch your SIM into another phone, To help us determine if its a phone or PM problem. Thanks. If it's not a phone problem, try these tricks to restart/ reset your phone service. You could try in order:
1. Restarting your phone. Turn your phone off, wait 30 seconds and restart.
2.Putting your phone on aeroplane mode for 5 minutes. Take it off and restart.
3.From your self service account enable the lost/ stolen feature log out, wait 5 minutes, log in and take it off. Log out and restart your phone.
4. Add a one time payment and of $2 To your account and restart your phone .
If these tricks don't work contact a moderator and ask them to reset your SIM. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on "Account specific question" and "No I want a human" and "Submit a ticket Click me!")
Once connected, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there. Once it does, you will be asked to verify your self service account, with your password and login. Doing allows the process to continue.
You can also enable email notification to receive a private message notification sent to your email. Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
Stay safe.
04-20-2020 02:47 PM - edited 04-20-2020 02:55 PM
Check were the nearest cell towers.
https://www.publicmobile.ca/en/bc/coverage
Try rebooting your phone.
If you have another phone then try swapping the sim to rule an issue with your phone.
