06-14-2023 01:24 PM
I have the 25$ plan. I am in New Brunswick and I am supposed to be able to call any provinces in Canada. But for example if I go to Nova Scotia I can't make calls to someone who is in that province.
I am trying to see if I can add it but I can't see where, the only add-ons I see is for the US.
06-14-2023 09:01 PM
maybe you're on the older province wide plans. try seeing if you can schedule a plan change to the current $25 plan
06-14-2023 01:26 PM
@coall Yes you can
06-14-2023 01:26 PM
HI @coall
you should be able to call from NS to NB or other provinces in Canada
Reboot the phone first. And dial with a 1 in front of the number
06-14-2023 01:26 PM
Try adding 1 in front of the number you are trying to call.
06-14-2023 01:25 PM
@coall if you are on $25 plan with Canada Wide calling, you can call from anywhere in Canada to any Canadian number. Try to add a 1 in front of the 10 digits
