Calling not working.
PeterD87
Hi, I recently changed to a 75gb plan, and I am no longer able to make or receive calls. As far as I can tell it should be included in the plan.
2 REPLIES 2
Dunkman
@PeterD87
If rebooting the phone does not help, maybe try a network reset of phone.  Note: this will erase any saved Wifi settings.
There are times when some aspects of the service don't work after a plan change until after the device has been restarted, although that's usually for data.  Have you tried rebooting your phone?
