Call from US to Canada failing
01-21-2024 06:45 PM
01-22-2024 11:17 AM
If you're in Canada, you can receive calls from anywhere (including USA) with any Public Mobile plan. If somebody else in USA is unable to call you then it's a limitation or problem with their plan, not yours. If you have a Canada+US Talk plan then you can dial to USA, if you have a Canada-wide Talk plan then you need a US Long-Distance Minutes add-on to dial to USA.
If you're in USA, you will not get any phone service unless you have a Canada+US Talk plan or a US Roaming add-on.
If you have service, you can access your account by dialing 611 or *611. If you do not have service, you can login to Self-Serve from any device connected to the internet, even a free WiFi hotspot at a fast food place.
01-21-2024 07:02 PM
What model phone do you have? Is it VoLTE compatible with Public mobile? What about text and data?
Here is some more information:
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
01-21-2024 06:47 PM
have you purchased one of the 15 Day US Roaming add-ons with talk or do you have a current US & Canada plan ? Without either, you won't be able to call Canada from US.
01-21-2024 06:46 PM
@DKemp Do you have CAN/US plan or US roaming add on ? If yes to either make sure the phone is set to 4G/LTE and connect to T mobile or AT&T . If you still have issues with voice try phone on 2G and connect to T mobile
