05-05-2024 10:29 PM
Hello,
call forwarding codes are giving error for iphone, Busy/no answer/ not reachable giving same error.
05-06-2024 03:31 PM - edited 05-06-2024 03:32 PM
@Channi wrote:Hello,
I had this same issue for over a year as well, but a few months ago I found that after testing my SIM in an older BlackBerry 10 device (which doesn't support VoLTE at all), it was letting me set and reset the call forwarding options. Then I found that the settings still continued to work in my original phone after that, as well as being able to continue to change the settings from the original phone as well after that going forward.
So maybe if you have or can borrow some old phone to temporarily put your SIM in, this workaround might work for you too...
Thanks to this, I can once again use YouMail for free visual voicemail by email by setting all my "conditional" forwards to that service instead of Public Mobile's default voicemail service which requires calling in to listen. (Which also means using some of my precious "Legacy" $15 plan 100 minutes 😁)
05-05-2024 10:34 PM
Ticket has been raised and will update for solution provided.
05-05-2024 10:30 PM
Conditional forwarding (busy/no answer/not reachable) have been broken for long time. The only forwarding works is the uncoditional forwarding. Sorry, PM is aware of the issue but no fix at the moment and no ETA
05-05-2024 10:30 PM
@Channi - Public Mobile has it broken for over a year now with no fix, maybe CS_Agent can:
Submit a ticket via Chatbot:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
