06-10-2023
09:37 PM
06-11-2023
11:06 AM
Dunkman
I am trying to set my phone to forward and I am getting the following error:
"CONNECTION PROBLEM OR INVALID MMI CODE"
I have tried restarting, being in safe mode and even reset the networks.
Any other solutions?
06-11-2023 08:24 PM
@ABbound wrote:I am trying to set my phone to forward and I am getting the following error:
Are you trying to configure "unconditional" forwarding, or one of the three "conditional" forwards? I've found personally since the switch to VoLTE that I can configure "unconditional" forwarding (for all calls, using the *21 code) but not the "conditional" forwards (busy, no answer, declined, using the *61, *62, *67 codes)
If your phone is using LTE network, as a troubleshooting step you could try forcing your phone to 3G mode to see if you see any change in the ability to set call forwarding or not.
06-10-2023 10:36 PM
@ABbound most phone on PM is now still using 3G network for voice.
PM allows selected phones to use LTE for voice, it's called VoLTE (voice over LTE).
however, Moto Ace 5G is not a compatible PM's VoLTE device.
So, sorry, the conditional forwarding won't work for you at the moment (Honest, not sure if they will fix it)
06-10-2023 10:33 PM
I don't what Volte is lol. I have a Moto Ace 5g.
06-10-2023 09:58 PM
since the enabling of VoLTE , the conditional forwarding was broken
However, if your phone is VoLTE compatible with PM network, and is using VoLTE, PM support can help and fix it (but if you are not using VoLTE, then sorry, conditional forwarding simply not working)
So, what brand and model is your phone? do you know if VoLTE is working ?
06-10-2023 09:55 PM
Yes, I can still place calls and send messages.
06-10-2023 09:50 PM
@ABbound Is your account currently Active? Are you able to place a call to anyone or send a text message?
