01-12-2022 01:36 PM
How can I set call control?
Call Control helps reduce unwanted calls by prompting incoming callers to enter a specific number, which the caller must enter correctly before the call can be connected. Callers with no response or an incorrect response won’t be able to complete the call.
How can I set this feature on my line?
01-12-2022 01:40 PM
Not offered here.
01-12-2022 01:40 PM
Not offered here.
01-12-2022 01:40 PM
at public mobile not have option like that..
01-12-2022 01:40 PM
PM has no Call Control
01-12-2022 02:09 PM - edited 01-12-2022 02:10 PM
You would have to port out to another provider (Koodo or TELUS) who offers this option, unfortunately.
You can, however, set your device to only accept incoming calls from selected persons in your contact list. Any callers who are not a designated contact would then be directed directly to voicemail, after which most would likely hang up if scam callers.
01-12-2022 02:45 PM
Sorry but PM doesn't offer that call control option. If you really want that option, you'll have to switch to either Koodo or Telus. Sorry 😐
01-31-2022 08:03 PM
The CRTC has required all mobile tel providers to have this, so I am not sure how PM is exempt.
01-31-2022 09:12 PM - edited 01-31-2022 09:12 PM
01-31-2022 10:04 PM - edited 01-31-2022 10:05 PM
01-31-2022 10:13 PM
HI @naddude
These CRTC rule is to fight Caller ID Spoofing. Telus has implement it but you need a new phone that support STIR/SHAKEN verification to work
Call control is not part of the requirement.
