11-03-2022 08:49 PM
11-03-2022 09:02 PM
Do you know your 4 digit account pin #? If so you can add funds and purchase US Roaming add ons thru 611. Otherwise try sending a private message again using the link in this post.
11-03-2022 08:59 PM
Thanks so much! The link worked for me. I was trying to input the CS Agent address by hand and it wouldn't take it. I really appreciate your help.
11-03-2022 08:50 PM - edited 11-03-2022 08:52 PM
@Taran did you message them here? what error you got?
