@CS_Agent
Carin1
@CS_Agent
It’s not accepting my new credit card.
8 REPLIES 8
@computergeek541
true, but there was a post talked about name issue.  The guy had card update issue, but once he  changed his long name  to initials and it works, so I wonder if anything changed
Also there was another one about address (which does not apply here as activation has no address entered yet), the guy has a PO box # on the address and payment "oops" all the time until it was removed
So, I wonder if PM has some internal check with name (and possibly address) for adding any card to the system.
@softech
The name on the Public Mobile account doesn't need to match that of the name of the credit card. Over the years, I have used the same credit card on different accounts.
@Carin1
is the name you use for PM account matches the name on the credit card?  On the other hand, if it is a long  name, maybe you need to shorten it with initials
do yoou have another credit card to use for the activation?
Carin1
I am using a Canadian Credit Card and entering the correct postal code.
still I’m getting an error message.
Priority
Also have you tried adding funds to your Account using the ChatBot?
Priority
Make sure the Postal Code you are putting in match the exact one on that credit cards statements and billing address, otherwise payment will not go through.
"please wish at least a full hour before trying"
I wish I may, I wish I might, be able to pay for my cell service tonight.
@Carin1 please wish at least a full hour before trying
Also, confirm your have a Canadian or US issued  Credit or Debit card
Make sure address and postal code entered correctly
