COVID Related Data Add-On?
mclarekinley
Hello, as everyone in my household is currently working from home, our internet has been extremely slow so I have been forced to use my data way more than usual. Is Public providing any sort of complementary data addon for these extenuating circumstances? Thank you!
Expanding @hairbag1 's suggestion, the absolute lowest cost data at PM is the $50 plan, with autopay, renewed early as needed. To renew early you make manual payment so that Available Funds equal your plan cost, then submit a ticket requesting the early renewal.
hairbag1
Maybe consider taking advantage of more data in a higher cost plan...then downgrade when you don't need as much data...even if only for 30 days. Probably a better more economical method than the $15/1GB add-on.
RossN
@mclarekinley hi no they are not but you can buy 1 gig for 15 dollars add on it is usually 30
kselmak
Not globally
You can reach out to them
https://publicmobile.ca.ada.support/chat/
gblackma
Sorry @mclarekinley at this point the only complimentary add on is ($15) 1/2 price for the 1gig add on. Stay safe. And enjoy the family time.
