Voice mail
franceswhite
My phone goes directly to voicemail . How do I solve this problem .
fdrcamb519
@franceswhite
Welcome to Public Mobile, make sure  you, Turn Off Do Not Disturb, and Airplane mode, off, in or, it will automatically, go voicemail. For sure not the case,here, but just in case.
kselmak
Are you in dnd mode?
RossN
@franceswhite if you recently ported follow @geopublic  advice if you have been here for awhile check to see if you accidently have do not disturb enabled
gblackma
@franceswhite Dial '#21#' to disable unconditional call forwarding if enabled. Welcome to the community.  Stay safe.  See article. https://www.publicmobile.ca/en/on/get-help/articles/call-forwarding
geopublic
@franceswhite  Did just let on your number from another provider? If yes, it can take up to 4 hours for the port to complete. Just continue to use your old sim until it stops working.
