CC info to update
06-14-2022 04:28 PM
Is there a contact phone number where I can call and update CC info. I am having sign in issues. I post 6 hrs ago. no response so far
Service
06-15-2022 02:34 AM
I had a lot of problems updating my cc. Took me a long time. Finally I had to remove the old cc and then replace with new card. Works fine now
06-14-2022 04:38 PM
Unfortunately no....there is no phone number to call. Have a read thru this post on updating your credit card info and it may help you. Otherwise contact customer support to gain access to your ac ount and/or update your card.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
06-14-2022 04:36 PM
Hi @Rajiv have you opened a ticket yet with PM support to unlock your account and reset password?
if not, you can request here at: https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
- First type: "Forgot log in information"
- Then Click "Contact Us"
- Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
Once you are back in, you can then update your CC info
06-14-2022 04:32 PM
@Rajiv hi if you are having issues signing in
1. hi you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
06-14-2022 04:30 PM - edited 06-14-2022 04:33 PM
@Rajiv - you posted where? Did you submit a ticket to CSA by either these two methods?
1- Put in a ticket through SIMon Bot (usually faster method to get in contact with the Public Mobile Customer Support agents=CSA) by clicking here:
OR
2- Private message CSA here (slower method) by clicking here:
Were you ever able to log into your account? If not, maybe you need to register for one.
edit...here is where you can register for a Self Serve account, IF You are a current customer with an active account:
If you have been able to log into self serve before, have you tried the Forgot your Password option?
Public Mobile - Forgot Your Password?
If you can get in, this is where you go change/replace/update your card info below.
