3G.
Options
2 weeks ago
Anyone else seeing 3G after iOS 18.4 update. Or doesn’t connect to anything else….
Labels:
Service
2 REPLIES 2
Options
2 weeks ago
@Sryder35 I haven't updated mine yet but I seem to think someone said the other day that 3G had disappeared from the settings after the update. Didn't say nothing else was connecting though.
Options
2 weeks ago
hi @Sryder35 you don't need 3G even you are on a 3G plan
doesn't matter what plan you have, you can connect to the 4G or 5G networks with PM, just the speed will be capped based on your plan
so, leave it with automatic and let your iPhone chooses the network
