a month ago - last edited a month ago by computergeek541
Not able to call US numbers since this morning from my CAN/US plan, any idea what is happening here ?
3 weeks ago
You are right, I can call other US numbers but not able to call a number with T-Mobile, I have a second public phone that also is not able to call this particular T-Mobile number, raised a ticket and waiting for a solution, thank you.
@janimathew Not all U.S. area codes can be dialed test calling US McDonalds restaurant and see if it works
adding @janimathew
List of U.S. area codes that cannot be called
712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726, 530-881.
a month ago
hi @janimathew oh, you are in Canada. Then forget the US networks suggestions above
try reboot the phone. Call with the 1 in front of the 10 digits. And try calling different US numbers
a month ago
@janimathew Set phone to 4G/LTE not 5G and make sure your connected to T mobile /AT&T or Verizon . Also note if your phone is not on thenPM voLTE whitelist using your phone for phone calls in the US will be difficult
VoLTE white list
a month ago
Yes, it was working well before, since this morning I can not make calls from Canada to US numbers
a month ago
hi @janimathew so it was working well before?
can you still receive calls in US now?
try using different network, but only use 4G . Try AT&T or T-Mobile or Verizon
if none of those work, try putting network mode to 2G and use T-Mobile
