CA US plan
TanyaWaiz
I have the unlimited Canada-US+talk+ text+20GB.  To be clear I am able to call a USA phone number from Canada and within USA at no xtra cost.  And able to call a Canada phone number while in the USA?
7 REPLIES 7
DennyCrane
@TanyaWaiz I'm assuming you're in Quebec? That's the only province that offers a 20GB Can/US plan ($43). The rest of Canada only has a $50/40GB Can/US plan.
But in answer to your question, yes
gbranscombe1963
Is this same thing for messages also? Can I text and MMS A US number and Can number while in Canada. While I am in the US can I text and MMS a US or Canada number?
Good of you to ask and clarify. Another detail is that this is a prepaid service. There are no extra charges if that was what you were concerned about. You could try calling Timbuktu and see what happens and you would not get charged...even if it went through.
TanyaWaiz
Thanks so much.  Will now place my call 😉
@TanyaWaiz  .YES that’s exactly right you can . Great plan too BTW
@TanyaWaiz
yes, this is a plan included with US roaming.  You can use data in US and make call to US while in Canada and also make and receive calls in US back to Canada (and to US)
Whether in Canada or the US, this plan includes unlimited calling, text, picture and video and messaging to phone numbers within and between Canada and the US. Data can be used in both Canada and the US.
Hi @TanyaWaiz
yes, you can
