03-14-2023
07:41 PM
03-14-2023
08:07 PM
computergeek541
Hi,
I'm trying to buy a new phone. It's not one offered through Public Mobile.
But I'm confused about what to look for:
Does it need to be unlocked?
Does the listing need to say it supports Public Mobile as a carrier?
Are there other carriers that are effectively the same, in terms of phone compatibility?
Thanks
03-14-2023 08:24 PM
Oh that would be great if I didn't already have one x) Thanks for the heads-up, anyway
03-14-2023 07:55 PM
I would suggest you take advantage of the free PM SIM offered today on the PM website!
03-14-2023 07:51 PM
awesome, thank you!
03-14-2023 07:51 PM
awesome, thanks!
03-14-2023 07:49 PM - edited 03-14-2023 07:56 PM
that cell phone will be perfect here on PM network.
added...
if / when PM ever decides to go to volte, you'll be happy to know your S10e is volte ready !! 😎
03-14-2023 07:49 PM
Yes, it will work with PM since the Samsung S10e is a 2019 phone.
03-14-2023 07:48 PM
Oh wow, okay. Thanks for the super-detailed info!
03-14-2023 07:48 PM
Oh interesting, ok. I wonder why so many listings say unlocked, then list a bunch of carriers... anyway, thanks
03-14-2023 07:46 PM
Public Mobile uses the following frequency bands:
Always good to check whether a phone will work with any provider, especially Public Mobile. Use more than one source to be sure.
https://www.kimovil.com/en/frequency-checker/CA
https://www.frequencycheck.com/
03-14-2023 07:46 PM
Okay, good to know.
I'm looking at the Samsung s10e
03-14-2023 07:46 PM
The must should be unlocked to work with all carriers. If the phone you are looking at is 2017 or newer…It will be unlocked.
If the phone is older than 2017, it will only work if it is locked by Telus or Koodo.
It won’t work if locked by other carriers like Bell or Rogers etc.
03-14-2023 07:42 PM - edited 03-14-2023 07:44 PM
what make / model are you considering ?
added...must be unlocked and not reported as stolen / blacklisted.
