4 hours ago
Hi! I am in the US for a bit and bought the add on for 3gb roaming data. I have lte connection but I'm worried I'm not actually using the data add on I bought and am getting charged separately from it. I am still at 0gb of 3gb after refreshing my data usage. Should I be worried?
55m ago
Thank you!
56m ago
It's strange because mid-flight in the US I got texts (from an app that uses WiFi which my flight didn't include) before I had purchased the add on. I had forgotten to also disable roaming before getting the add on. Just hoping I don't get hit with a big bill in the end... Thanks.
an hour ago
Thank you! 🙂 will do.
an hour ago
Ah I see, thanks so much! I'll keep an eye out to see if it changes later too.
3 hours ago
@Mittenui we had another customer report yesterday that their data usage in the US was not updating leaving them unaware with how much data they had used and how much was left. They said it took days before the usage was showing and that was through the PM app and the website. If you can, track your usage through your phone's settings
3 hours ago
No I wouldn't be worried. I would suggest you change to VoLTE for voice calling and if your phone is 5G compatible...change to 5G Auto. 3G has been decommissioned so you can only connect to 4G & 5G.
2G is available on T-Mobile.
Enable Roaming and connect to AT&T or T-Mobile...whichever has a stronger signal.
3 hours ago
PM is a prepaid service. If the data wasnt working you would have no service.
3 hours ago
make sure to enable Data Roaming in setting. Should only connect to AT&T or T-Mobile... As long as you got the correct US add-on, you're good to go.
