03-02-2024 01:18 PM
Hi there
1- I have Samsung 8+ and I switched to the 5 G but it doe s not work and I am unable to switch back whats my options?
2- I need my sim car password or PIN number to be able to lock it in case I loose my phone
thank you
03-02-2024 04:05 PM - edited 03-02-2024 04:43 PM
@zagga wrote:Hi there
thank you
@zagga , For question # 2: I was told that the default sim card pin# to lock it was 1234 then you could change it after inputting that but not positive if that information is correct or where you would find it. It is best to ask CS_Agent for help with that to avoid issues using it yourself.
Edit: I tried entering 1234 and it worked. Then I changed to a different one.
Also, I found a post regarding that: Enabing and setting SIM pin
03-02-2024 01:21 PM
you sure it is a sim card PUK you need and not carrier unlock code?
for not issues, open ticket with support
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
