10-25-2022 06:55 PM
I couldn't find a clear answer, so thought I'd try here. I want to protect against port-out attacks and similar security issues by having a SIM PIN. When I was overseas, the SIM PIN where I was came automatically activated and you had to enter it anytime you rebooted your phone. If I read correctly, Public Mobile SIMs come with a default SIM (1234). How would I enable the SIM PIN and then change it? Thanks!
Other
10-25-2022 07:20 PM
Thanks! That turned to be easy. I have an iPhone. On an iPhone:
(1) Go to Settings > Cellular > SIM PIN
(2) Turn SIM PIN to "On"
(3) When prompted, enter the Public Mobile default SIM PIN (1234)
(4) Select "Change PIN"
(5) Provide your own four-digit PIN
The iPhone advises you have three attempts at a correct PIN before the SIM is locked.
I've set mine successfully now. Thanks again muchly.
10-25-2022 07:06 PM
The method for enabling your SIM PIN varries greatky depending on your device's software. On my phone, it's under Biometrics and Security, Other Security Srttings, Set Up SIM Card Lock.
