Bonus data $15 plan
martik777
Do I get any extra data over the 250mb if I signup  for autopay.
If so, does it ever expire?
@martik777
Missed the bonus data by 4 days as in you JUST signed up for service with PM or you missed replying to the text message offering the bonus by 4 days? The requirements to be offered this bonus Have been kept very quiet, it appears to be most but not all customers in BC and Alberta who were eligible. I dont think there is any way of knowing what would happen if you asked but I would guess that if you weren’t a PM customer on the date of the offer there would likely be no chance.
AE_Collector
martik777
I missed the 5GB free data by 4 days! I wonder if I could still get it if I  ask nicely 🙂
@martik777
If you think you need a little more each month just purchase the $15 1gb data add on. It does roll over so it can supplement your 250mb if you run out. But if you find your using close to 1gb total per month then you are better off with the $25/1gb or $30/2gb plans if more is needed.
The 250mb IS the autopay data.
hairbag1
Nope...with Autopay enabled you'll get 250MB's every 30 days at plan renewal. Remember...your regular plan data doesn't roll over. If you don't use it, you lose it. You'll get a fresh batch of 250mb whenever your regular plan renews.
