Bonus add ons
Crowbait
If I run out of data will my bonus add on data be used?
hi @Crowbait it will kick in, but sometimes you need to reboot the phone and remember to disable data limit
Crowbait
Thank you
@Crowbait - once your plan data runs out, if you have regular data addons on your account (not roaming ones, those are used only in USA), then YES your addons should kick in.
edit, NOTE: addons only work on an Active plan. So if you let your plan go into nonpay status do not expect to be able to use data addons.
