Blocking outgoing calls
FTT
Hi Community, is there a way to block an outgoing call made from your teenager?  For example, if he called a certain number it would not work. Thanks,
7 REPLIES 7
One way that I know of what be to get a specialized device that only allows phone calls to specific pre-programmed phone numbers. Howver, those types of devices are usually aimed to suit the needs of much younger children.  To prevent someone from simply taking the SIM card out and putting into another device, the PIN card prompt for whenever the SIM is inserted into a different phone option would need to be enabled.
@slusagm wrote:
disable the dialer app
I don't see anything that would stop anyone from re-enabling the the dialer.
markmitsu
Have you looked into data plan and use app calling
FTT
How do I prevent the teenage from calling one number in particular?
HI @FTT
if you want to completely disable outgoing calls, turnon Call barring
or use app like SureLock to block calling to certain numbers
Sansan
The recipient is usually the one that blocks calls. But they can leave voicemail.
slusagm
