3 hours ago
Hi, I'm travelling soon. I want to know in the about canada-us plan. on your website, there is a 45$ plan with 65G of data and unlimited canada-us wide.
Do i need to buy roaming minutes and data add on to use this plan when i travel to the US?
let me know. TIA
2 hours ago
Also enable VoLTE (voice over LTE/4G) along with enabling Roaming on your phone.
3 hours ago
No roaming minutes required, jsut make sure you have the roaming feature on your phone turned ON.
3 hours ago
the canada-us plan include everything. You use the phone like you are home
3 hours ago
hi @Thithy
no you don't need extra addon if you get the Canada-US plan
The Canada-US plan include data, calls and text. You can call from US to Canada and US
just need to make sure you enable roaming data on your phone and connect to T-Mobile, AT&T or Verizon
