05-15-2019 03:22 PM - edited 01-05-2022 07:30 AM
I have had a salesperson keep calling me despite telling them I am not interested, so far I have been able to block their calls. Only issue is that they are still able to leave a voicemail, do you know if it is possible to block them from leaving a message as well?
Service
05-23-2019 05:42 AM - edited 05-23-2019 09:42 AM
@srlawren wrote:
@geopublic wrote:
@dmbcanada wrote:I have had a salesperson keep calling me despite telling them I am not interested, so far I have been able to block their calls. Only issue is that they are still able to leave a voicemail, do you know if it is possible to block them from leaving a message as well?
@dmbcanada What type of phone do you have. If it's an Android phone you can mark it as spam and add it to the list. If you have a Pixel phone you can use the call screen feature.
@geopublic that only blocks the phone from ringing, which @dmbcanada has already done. They are looking for a way to prevent the person from leaving a voicemail!
@dmbcanada ...which unfortunately is not possible. You can either prevent everyone from leaving voicemails (workaround detailed here: Workaround for diabling Voicemail), or prevent nobody from leaving voicemails.
Yes, that is a link to a good post on managing your VM. For a more complete discussion of all your options regarding VMs, read this thread:
05-16-2019 07:53 PM
Did you try registering with : https://www.lnnte-dncl.gc.ca/en
05-16-2019 02:32 PM
I have reported the individual who has calling me to management and they have taken care of it. Hopefully I do not have to block anyone else as it doesn't seem like a easy fix.
05-15-2019 05:23 PM - edited 05-15-2019 05:24 PM
The only way that I know od to block voice messages for most phones from a specific number would be to use a third-party app. These work by answering the phone call and then hanging up. Truecaller comes to mind but there are many others. You would have to first remove the number from your phone dialer's/contacts app blocked list. Unfortunately, to accomplish all of this, your phone will ring briefly before the app can answer the call.
05-15-2019 04:30 PM
@geopublic wrote:@srlawren On my Pixel when I report a number as Spam I never get a call from that number.
@geopublic Oh yeah I forgot Pixels have additional assisant features baked in that pick up the call for you and dismiss the person. Thus, the call never reaches your voicemail. I guess yes if you have a Pixel, this is a possible workaround. But simply blocking the number on most phones will only cause the call to go directly (or nearly directly) to your voicemail.
05-15-2019 04:25 PM
05-15-2019 04:18 PM
05-15-2019 03:29 PM
Good question, if you block from your phone they will end up in Voicemail.
I don't believe there is an option to block numbers at the PM level which would completely block the calls that you don't want....
05-15-2019 03:28 PM
