11-28-2022 03:27 PM
Hello, I am an existing public mobile customer. I just edited my plan to take advantage of the "20OFFMONTHLY" black Friday sale. This is where I save 20 dollars off the 55 dollars for the 20GB plan. This plan is supposed to take effect at renewal. But my account dashboard says it will cost 55 dollars and I don't see the discount. I want to make sure that the promotion went through.
Even though I don't see the promotion is the promotion still activated?
11-29-2022 11:37 AM
you have to change plan immediately not on renewal date, I just did, it works.
11-28-2022 03:46 PM
@GarrettF wrote:Seems to be some confusion. So has it been confirmed that existing customers will be able to take advantage of this plan?
Yes, some confusion. You can always contact an agent to see what they have to say.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
11-28-2022 03:45 PM
Only known, with change now. Been customer of PM for 4 years
11-28-2022 03:37 PM
11-28-2022 03:31 PM - edited 11-28-2022 03:33 PM
