06-08-2025 12:13 PM
I have a friend that tried to sign up on Friday, and they didn’t know about this promotion. They tried to use my referral code, and it said it didn’t work unless it was a $29 or above plan (they were signing up for the $22 plan). Can they not still get the regular credit?
06-08-2025 06:06 PM
removed incorrect information
06-08-2025
12:50 PM
06-09-2025
01:47 AM
computergeek541
Hello @Jess101
Yes, there is currently a promo for $29 plans. You get a $15 one time credit within 45 days and they get $10 within 72 hours and then $15 within 45 days. However, there is no reason why the code wouldn't work. The $10 credit still works on any plan. You will have to ask them to create an account here on the forums and THEY will have to contact a CS Agent to advise the code didn't work. They will need some information from you so be prepared. Here's how they can properly reach a CS Agent when they log in.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
06-08-2025 12:47 PM - edited 06-08-2025 12:47 PM
Friend code works for all plan. Your friend could have typed in wrong
ask your friend to activate first even without the code. He can then ask PM to add it back to claim the $10 credit
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
Or you can also message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
