Billing issues
Adamsday1989
I was double billed when subscribing due to error. How do I talk to an agent get this rectified?
Thanks,
7 REPLIES 7
Chalupa_Batman
Hello @Adamsday1989
First and foremost, please contact your credit card company and confirm this is actually a double charge and not a "charge" + "Pending". This misdiagnosis happens often.  If it is just a "pending" then it's all good. If it's actually a double charge, then a link to the CS Agent has already been provided below.
¯\_(ツ)_/¯
test.ok?
hi @dust2dust
never experienced your issue.  I am ok, maybe I typed too much 😅
dust2dust
I'm quite often seeing that if I type just a few words that the reply doesn't get posted. What more words are needed to say contact support here and then the link. Irritating. Has this changed?
hi @Adamsday1989 first make sure from credit card if one of the two just a pending charge
if both are posted, then submit ticket with CS agent by messaging
ileefarrell
It is better to open a ticket (a link will probably shared with you in the comments by another member) or tap 'Get Help' to solve the problem with a customer support team member. It is generally tackled in an hour or more.
