12-12-2023 03:24 PM
I am thinking about switching my current plan at renewal to the boxing day promotion of 60GB Data for $45 monthly ($40 per month with 90 day subscription).
Is this plan unlimited data at reduced speeds? It seems the disclaimer changes from saying it is unlimited to not being unlimited depending on where it is being advertised on the Public Mobile website.
Thanks.
12-12-2023 03:30 PM
It’s unlimited. After you use up your 60gb it will reduce speed. I have unlimited data and I didn’t really notice much different after I use my GB at 5 speed. Maybe for downloading movies etc! But every month it’s unlimited after you use the 60gb 😉
12-12-2023 03:29 PM
@Anthem2023 It is unlimited data throttled to 512kbps after the data bucket is used up , just be sure to make plan change for next renewal
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
