12-07-2024 02:58 PM
I have the new Canada-USA-Mexico plan, I am in Mexico now, can I call and text Mexico and Canada unlimited without any additional charges? Also use data? Thank you.
01-02-2025 10:29 AM
I haven't had any issues other than it being slow to connect sometimes. Maybe you need to add the +1 country code first? Good luck.
01-01-2025 04:54 PM
I cant call back to canada on my canada us mexico plan
12-07-2024 05:10 PM
@Meow wrote:If you have Can/USA/Mex plan there is NO difference in which country you are!
Depending on your plan, if it says unlimited calls/sms then it will be that way in either countries. If you have data limit you can use it up to that limit in either country and Depending on your plan you might have 'unlimited' data but with slower speed.
Really great plan if you move between these 3 countries often. Enjoy!
Unfortuantely, the above isn't correct. There are no plans at Public Mobile that have unlimited data that can be used in US or Mexico.
12-07-2024 03:40 PM - edited 12-07-2024 03:43 PM
Yes with Can/Us/Mex you can call, text and use data include in your plan while in Mexico. Turn on roaming and you will connect to Telus or one of their partners and you should be good. Have a nice trip!
CAN-US-MEX Subscription Plans | Help Article | Public Mobile
12-07-2024 03:03 PM - edited 12-07-2024 03:04 PM
@pammers wrote:I have the new Canada-USA-Mexico plan, I am in Mexico now, can I call and text Mexico and Canada unlimited without any additional charges? Also use data? Thank you.
Hey @pammers
You can call back to Canada and the US free of charge. Unlimited!!! No extra fees!! AND you can use your allotted data down there too... no extra fees! Remember, Public Mobile is a prepaid service. You prepay for what you want. You wanted the Can/US/Mex plan, you got it man! Enjoy your trip!!
