BMO Mastercard debit failing for new account
toomanycats
I am trying to set up a family member with Public Mobile, using the same BMO Mastercard debit I use for autopay. However, it now refuses to accept the card with a "We were not able to process your payment. Make sure all information is correct or try again with a different card."
The only information I had to put in was number, postal code, expiry date and security code. All of this is correct.
No other card is available for use.
What do I do?
toomanycats
I tried the advice to use a different browser and it worked!
Thank you 🙂
HI @toomanycats   you should have an account created when you first joined, unless you joined in retails kiosk
But you can simply submit ticket with CS agent and they will help out with the account issue
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
toomanycats
I cannot login to "My Account" because there is no account. This is the initial creation of the account, and I cannot continue without enterting the card details.
Yummy
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Since you already use that card to pay PM for another account if everything fails contact agent for assitance.
HI @toomanycats
Mastercard debit should work, some people had success adding to My Account.  However, it is true people struggle more with MC debit
Try to wait an hour first before you try again.  Use Incognito/Private/Secret mode to login to My Account to add the card
if still does not work, please submit ticket with CS agent and they might be able to help putting it for you
First type Contact,
from the list of , choose "Other"
