09-10-2017 09:50 AM - edited 01-04-2022 02:36 PM
My phone will is automatically cancelling outgoing calls to one phone number. That number is able to call me, but I cannot which means the problem is with my phone. I already rebooted my iPhone and also I have reset the network settings. Still this remains to be a problem. Is there anything else I can do?
09-10-2017 10:38 PM
Sometimes, the carrier will play some type of automated failure message, but those messages sometimes get cut off at the start of them causing you to only hear the end of the message or none of it at all. If that happens on some type of "caller is not available", "number not in service", or "call cannot be completed as dialed" message, you necessarily know why it happened and the phone will just drop the call.
09-10-2017 04:45 PM
Now it is occuring with a more people I try to contact and I have also check that I have nobody in my blocked list.
09-10-2017 04:44 PM
Yes it is within my province and now I cannot contact a several people in my contacts.
09-10-2017 02:29 PM - edited 09-10-2017 02:31 PM
@Isabel22, is the number you are trying to call in the same province that you are in?
If its a long distance number within your province, try putting a 1 in front of the number.
09-10-2017 10:56 AM
09-10-2017 10:26 AM
I am not an iOS user, but I would imagine it's a dialer setting that is causing the block. Go through the menus and see if there's any function which block contacts.
