08-10-2021 04:09 PM - edited 01-06-2022 03:05 AM
I activated my son’s new SIM card earlier today and used my credit card to set up autopay, but the system didn’t ask for credit card holder name. Is that normal? I wondered if the system thought the card holder is my son(mobile account name is his). If so, there will be a problem with the payment.
Joining Public
08-10-2021 07:33 PM
@Wynne1975 : It is goofy. Because it would make life a whole easier for folks to just enter in that required information rather than the whole name and address when changing or updating their card.
08-10-2021 07:23 PM
Great thanks. I saw a pending charge on my credit card from PM, so I think it worked. It’s really goofy that they didn’t ask for card holder name.
08-10-2021 04:37 PM
Thanks all. I will try later.
08-10-2021 04:34 PM
@Wynne1975 : Did the activation go through and get paid for? If so, then it worked. But it is a goofy thing that during activation they don't ask for name/address but if you need to do something with the card afterwards, you need to enter all that. Go figure.
For more certainty, indeed test it out with a dollar.
08-10-2021 04:20 PM
@Wynne1975 if you want to be safe, try to do a manual top-up and see if it goes through
To be really safe, go to the Payment Tab, Manage My Card and Replace Credit card to "replace"/ re-enter the current card you have. They will ask you for the card holder name when you re-enter.
08-10-2021 04:18 PM
Thanks for your reply. But when I activated his SIM card, I also use my credit card and there was no space to enter card holder name.
08-10-2021 04:17 PM
Try doing a manual $1 Top-Up... if it works okay, then AutoPay should also process okay. Keep an eye out for any problems. If it works okay, I'd leave it... 🙂
08-10-2021 04:12 PM
@Wynne1975 Autopay uses the credit card already setup on your account. I believe when you set it up, you already put the name there.
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
